Revit MEP Forum
Not getting flowrates for AHU supply and return main ducts
3 REPLIES 3
1141 Views, 3 Replies
my revit project file. Im completely new to revit , just installed yesterday. I cannot get the flowrate in the main ducts TO and FROM the AHU. But I am getting flowrates in all other branches .
Link for the project file :
https://www.dropbox.com/s/utavebf1pe...ified.rvt?dl=0
Attached Image for easy review
3 REPLIES 3
georgemcfaulds23
Hi there,
If you go to View > User Interface > System Browser.
This will tell you if you have any ducts which are unconnected. Once connected all flow rates should show. Rates can be changed via grilles (in properties window).
Hope this helps.
Kind Regards
George McFaulds
in reply to: georgemcfaulds23
Thanks a lot bro. I came to know that there were problems in connections within ducts. I used the system browser , understood the problem, analyze tab -> show disconnects option near check duct system. Thankyou
georgemcfaulds23
No worries at all, I had the same issue a few months back. Glad to help.
Cheers
George
