I installed REVIT MEP 16 (student version) in BOOT CAMP with Windows 10, on a Macbook Pro with the following specs:
Processor Name: Intel Core i7
Processor Speed: 2,5 GHz
Memory: 16 GB
And REVIT is not running correctly. It seems that there is some problem with the graphic card as the drawings don't load completely.
I have tried to install an available update but the installation is failed because it doesn't find a AMD hardware.
Is there a step that I am missing?
Hi @Anonymous and welcome to Autodesk Community!
Apologies for the issue you are having.
I have escalated your issue to our product support on case 12139094 and they will be contacting you directly via the case to solve the problem.
Thank you for your patience.
The solution in my case was easy.
The problem was in the settings for the display in Windows mode.
In my case it the zoom was set to 200%, and because of that the refresh rate was too fast.
I changed it to 100% and it was fine. You get bigger icons but it works.
Good luck
