Hi, im quite sure this has been asked for ages but could we please get Revit up decent level for electrical engineers who need to model really accurate models and make decent 2D plans with wires.
New system families:
- Busbars and busway system families
- Trunking system
- Electrical supply track for luminaires/sockets
Please!
Wire drawing is quite bad at the moment atleast for Nordic stantards.
What we really need:
- Another wire type "straight" wire line not arch or chamfer just a straight one. Chamfer can do the trick up to a point were it just maked everything really bad when you have to modify the wires.
- You need to be able to split wire lines (and join them back to together). Its just too time consuming to draw long wire lines between devices and then see that you forgot to connect something or you need to add stuff in between... You just delete everything and start all over again. Not good..
- Please make wires moveable between two vertexses.. its feels like who ever made the wire tool in Revit doesnt understand that the wires needs to be moved alot in normal design projects and moving one vextex at a time is just painfull.
-Miro
Go to the Ideas forum, search for a similar request and vote for it. If none exists then post a new Idea.
https://forums.autodesk.com/t5/revit-ideas/idb-p/302
You could also respond to this post
