- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am attempting to run a filter that will hatch my insulated ducting. No matter what scale/line spacing or type of fill pattern I change to, every time it appears as solid fill. I zoom all the way in and all the way out and it still appears as solid fill.
Also, when I print to PDF the "pattern" completely disappears, so I am not sure if this is an issue with overscaling, but again I have tried extremely tiny scale and extremely large scale and everything in between to no success.
The filter is picking up all the correct duct I want to hatch, so I have those settings down correctly. It's just that they are solid filled and not a pattern.
I tried googling and I watched a ton of videos, nothing has explained the problem. I have tried everything and done my due diligence and I cannot seem to solve this problem. I am fairly new to Revit so it may be an easy solution that I can't solve. These fittings I am trying to hatch are fabrication parts from my office database and not Revit families.
I am running Revit 2020.
