Modify | Floors Sub Elements
Message 1 of 9
HI
I have done Revit training with autodesk partner. I want to refresh my memory and repeat some workflows but on my Revit MEP there is some functionality missing.
Screenshot from Youtube :
My Revit :
Maybe is it because I work on MEP (Revit MEP 2016 SP2), and training was done on Architecture? My trainer could not answer my queston.
I need to modify Floor - Structural.
Thanks a lot !
Replies (8)
Message 2 of 9
rudi.roux
Hi @Anonymous
Welcome to the community! Smiley Happy
Just to make sure, are you on Revit 2016 (Full Version) or on Revit 2016 LT (Lite)
If you are on Revit 2016 LT, then that function (Shape Editing Panel) is unfortunately not available.
Revit Architecture / Structure and MEP forms part of the same software package, basically since Revit 2016.
You'll notice Architecture / Structure and Systems tabs right at the top left, next to the "Big R".
I wanted to say that you're plan view is possibly in the incorrect Discipline (set to a discipline other than Architecture or Coordination), but that would then mean that you won't be able to select the floor in the plan view in the first place to Edit the Boundary.
I rate that you are possibly using Revit 2016 LT.
I hope this helps! Smiley Happy
Rudi Roux
MSc | Digital Engineering Manager
LinkedIn
Revit Mechanical & Electrical Systems 2018 Certified Professional | Revit MEP & Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional | Autodesk Building Performance Analysis (BPA) Certificate
If this post resolved your issue, kindly Accept as the Solution below. Kudos are always welcome
Message 3 of 9
Hi Rudi
Thanks for commitment!
I'm on full Revit.
It was coordination, now is set up to Architectural.
You're right, when I switch to another discipline all elements are in read-only mode.
One person from support contacted me about that. He send me a documentation to check, page 3. But after unzip I can't open that file it seems to be Java Script.
Password for archive: documentation
https://www.dropbox.com/s/068wct59hvy9gob/documentation-UPD2016112...zip?dl=0
Still have no idea what's going on.
Robert
Message 4 of 9
Robert
 Ok, so that PM was a fake message with malicious software attached.
Message 5 of 9
rudi.roux
Hi @Anonymous
Strange indeed, would it be possible to share the problematic model with me so that I could investigate it for you? Nothing in your direct settings in your properties pallet is incorrect.
Rudi Roux
LinkedIn
Message 6 of 9
Hi Rudi
of course, please find attached file.
I've installed today trial version Revit Architecture 2016 and that feature works.
On my Revit MEP 2016 is gone.
I thought that the MEP will have these features.
Robert
Message 7 of 9
rudi.roux
Hi @Anonymous
Ahhhh yes, I know you mentioned that you were on Revit MEP in your first post and when I started to query whether you were on "full" Revit or only only LT, I was referring to "Revit 2016" as can be seen below: (My apologies for diverting).
LINK to the page where I pulled the image from or you could use Autodesk VIRTUAL AGENT to download a desired version or Revit or other Autodesk Software.
I prefer the one which I indicated above, because you'll have full functionality for all disciplines and where you would not need to shift between e.g. - Arch / MEP / Struc.
In Revit, Revit Architecture or in Revit Structure you would have access to the Shape Editing Panel, but not in Revit MEP or in Revit LT.
I hope this helps! Smiley Wink
Rudi Roux
LinkedIn
Message 8 of 9
Hi
It's sad that I don't have that feature, but I still owe You a drink.
Case closed.
Thank You
Robert
Message 9 of 9
rudi.roux
Hi @Anonymous
It's a pleasure! Smiley Wink
Why don't you go and have a chat with your ATC/Software Provider where you received your training/software from and try and arrange a License upgrade/swap to the Revit 2016 Version which I indicated? This might then also resolve a couple of future issues for you.
Rudi Roux
LinkedIn
