Missing Flange Between Fitting and Transition (Reducer Fitting)
This is a Charlotte Cast-Iron No-Hub Family. It requires some kind of a Band as a coupling. Here i am using a Flange as that Band. And a Reducer as my transition Fitting.
In the image, you see that as i draw a pipe and change pipe size, Revit (2020) added a band between a Pipe and a the transition Fitting But not between a Fitting and the transition Fitting - in this case an Elbow and a Reducer.
In the field a band would be used there... by simply butting the Fitting to a transition fitting with a Band around them.
So What drives the insertion of a Flange(Band)?
How can i fix the family or Routing Preferences to insert a Flange (Band) between Fittings and transition fittings?
