Missing Flange Between Fitting and Transition (Reducer Fitting)
fawzimasri7137
fawzimasri7137
This is a Charlotte Cast-Iron No-Hub Family. It requires some kind of a Band as a coupling. Here i am using a Flange as that Band. And a Reducer as my transition Fitting.
In the image, you see that as i draw a pipe and change pipe size, Revit (2020) added a band between a Pipe and a the transition Fitting But not between a Fitting and the transition Fitting - in this case an Elbow and a Reducer.
In the field a band would be used there... by simply butting the Fitting to  a transition fitting with a Band around them.
So What drives the insertion of a Flange(Band)?
How can i fix the family or Routing Preferences to insert a Flange (Band) between Fittings and transition fittings?
hmunsell
a Flange will place between the pipe segment and a fitting,  but I don't believe a flange will place between 2 fittings. you would have to model it into the fitting, maybe as a visibility option. You can try placing them manually, but I haven't had good luck with that since they don't like to connect properly when placed manually.
Howard Munsell
fawzimasri7137
So Revit looks only at whether it is a Fitting to a Pipe and then makes the decision to add a Flange?  nothing else influences that?
if i merge the flange with the fitting, then i would have to manually enable/disable visibility, or thru some macro, correct? i am worried it will be yet another thing that one could forget to do.
I wounder if it is better to add the flange using some kind of macro.
iainsavage
I had a similar issue with Victaulic fittings and ended up nesting the couplings into the pipe fittings with visibility parameters to control them in the few instances when there’s a fitting-to-fitting connection.
https://forums.autodesk.com/t5/revit-mep-forum/splitting-grooved-pipework-adds-2-couplings/td-p/1016...
There are some addons which will do this automatically but I they need to be paid for.
