Revit MEP Forum
MEP Duct connection not loading its family in revit 2019
2 REPLIES 2
P93mahapatra
336 Views, 2 Replies
i tried to load revit 2019 but the MEP content is already loaded in revit. still i cannot connect the fitting to the duct or diffuser
2 REPLIES 2
hmunsell
in reply to: P93mahapatra
check your Routing Preferences for the Pipe Type.  make sure there are the fittings loaded you need.
  • pick your Pipe Type
  • Edit Type Properties
  • Edit Routing Preferences
  • assign Fitting Families in the appropriate catagories as needed.
Howard Munsell
You habe to define your routing settings for ducts/pipes.
Forma Design Contest
Technology Administrators
