Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
How do you get MEP content to show up in Detail View callouts?
Go check v/s overrides. Check mechanical / plumbing what you need to see.
Check template . If you use arh. template you cant see mech. elements.
Eng. Iliev L.
⁞|⁞ BIM Implementer, Project & BIM Manager, Coordinator, MEP Engineer
⁞|⁞ http://www.TechRoom.bg
its all on.
IF I enable the geometry in the family to be visible in plan views you can see that but just not the nested symbols which show up in plan views OK.
There are several reasons they might be hidden.
Make a view template from the main plan that is showing them, then apply that template to the callout view that is not showing them. Maybe don't include view scale in the template.
I tried it and get exactly the same behavior. The nested annotation family used for the symbols just won't show up in a detail view callout no matter how much I fuss with all the possible settings.
Will you be able to use a floor plan callout instead?
It's a workaround in some instances but it does seem somewhat lacking
