Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Revit MEP Forum
MEP content in Detail Views
6 REPLIES 6
russ.green
436 Views, 6 Replies
How do you get MEP content to show up in Detail View callouts?
Russ Green
6 REPLIES 6
Go check v/s overrides. Check mechanical / plumbing what you need to see.
Check template . If you use arh. template you cant see mech. elements.
Eng. Iliev L.
⁞|⁞ BIM Implementer, Project & BIM Manager, Coordinator, MEP Engineer
⁞|⁞ http://www.TechRoom.bg
its all on.
IF I enable the geometry in the family to be visible in plan views you can see that but just not the nested symbols which show up in plan views OK.
Russ Green
chrisplyler
in reply to: russ.green
There are several reasons they might be hidden.
Make a view template from the main plan that is showing them, then apply that template to the callout view that is not showing them. Maybe don't include view scale in the template.
russ.green
in reply to: chrisplyler
this shows the issue.  http://autode.sk/1ALehR8
Russ Green
chrisplyler
I tried it and get exactly the same behavior. The nested annotation family used for the symbols just won't show up in a detail view callout no matter how much I fuss with all the possible settings.
Will you be able to use a floor plan callout instead?
russ.green
It's a workaround in some instances but it does seem somewhat lacking
Russ Green
