MEP annotation scale problem
peerawit.ru
peerawit.ru
Hi everyone
I try to create MEP family that unsymmetrical when i changed primary of connector and load into project then symbolic change too.
How are explained that Revit use annotation scale reference from what?
I think this function try to scale symbolic from setting but i don't know it scale form what logic?
thank for your recommend
fabiosato
I believe the scale considers the origin point of the family.
Fábio Sato
iainsavage
I think it is roughly the printed size of the fitting on a sheet based on the symbols hosted on the same planes as the pipe connectors in the family.
So if you have a valve which is symetrical around the Centre Left/Right plane and the setting is 3mm then on a sheet the symbol should be (about) 3mm long.
I don't think its a precise science though.
If you have a fitting which is not symetrical the results become a bit weird.
Here's an old post which is on a similar topic
https://forums.autodesk.com/t5/revit-mep-forum/single-line-valve-symbol-size-and-masking-pipe-ends/m...
