Spaces not visible in Floor Plan/RCP, but they are in section views.
alfredo.aceves1
Message 1 of 9
alfredo.aceves1
I am having some trouble with spaces having no visibility on my RCP. When I hover over the RCP after clicking spaces under the Analyze tab, no space to tag shows up. If I pull up a section view after hovering hover the RCP, it shows that a spaces is there, but it just doesn't show up on the RCP. I checked under visibility/graphics > model annotations > spaces. That is turned on, but it still won't show. Any help would be appreciated.
Replies (8)
Message 2 of 9
Check phasing of the RCP view.
Message 3 of 9
alfredo.aceves1
I checked the phasing, it is set to new construction. This is the same for the space.
Message 4 of 9
Looks like you have a view template.  Is V/G Overrides Model box checked in the template?
Message 5 of 9
alfredo.aceves1
Yes, it is checked for the template.
Message 6 of 9
Reveal Hidden Elements?  Filters?
Message 7 of 9
alfredo.aceves1
I have checked these as well, but no luck. I have some floor plans with different templates that do show the spaces. It seems it may be an issue with the template I have set.
Message 8 of 9
Message 9 of 9
alfredo.aceves1
Alright, I figured out the issue. It was my view range. I had the cut plane set to the same level as the floor. Although, I'm not entirely sure why it makes a difference. Whether the cut plane is set to the floor level or 5' above the floor level, the defined space should still be between the cut plane and top view, so it should be visible.
