MEP analyze - error
MEP analyze - error
YoavG88H3Z
Message 1 of 9
MEP analyze - error
YoavG88H3Z
Hello everyone !
I need help in solving this error message :
"SA 1583: It is not possible to calculate the flow since there is inline equipment that is configured as end of line. Please check equipment in this system and make sure that the equipment connectors used inline have a global system classification and a calculated flow configuration. Global equipment connectors used inline should always be linked to each other."
(I'm Trying to produce a pressure drop report for the ductwork)
Replies (8)
Message 2 of 9
RobDraw
That message describes what Revit needs in order to do the analysis, pretty clearly.
Have you checked all your inline equipment? (I've seen VAVs incorrectly categorized as air terminals.)
Rob
Message 3 of 9
YoavG88H3Z
I got only diffuser and dampers installed on duct-work connected to AHU...
no vav's...
Message 4 of 9
RobDraw
Have verified that the families are setup correctly?
Rob
Message 5 of 9
YoavG88H3Z
What do you mean by saying correctly?
Message 6 of 9
RobDraw
Try the stuff in the message?
Rob
Message 7 of 9
YoavG88H3Z
YES, I have been tried to change it to global connector but still I got that error.
Message 8 of 9
RobDraw
Did you address the FIRST sentence in the error message?
Rob
Message 9 of 9
iainsavage
Make sure the damper is a Duct Accessory.
Part Type "Damper".
Make both connectors Global.
Set them as bidirectional.
Set their flow configuration as Calculated.
Link the connectors.
