Hi
I use revit 2018 And i want to return text from lookup table .
1- I used BS##other## and BN##other## for header of my columns that had text and number (image1)
2-In revit family type i created parameter : Name:Bolt size Discipline:Common Type Of parameter : Text & Instance
3-in formula i typed size_lookup(Lookup Table Name, "BS", "NA", Nominal Diameter) and i got this error "Inconsistent Units"
4-when i exported csv file i wondered because i saw my headers hsd been changed to BS##number##feet And BN##number##feet
Hello @mehrdadjavaheri,
lookup tables, also called 'Size lookup tables' have columns that contain only size data. So only numbers no text.
So you can't make a column with text that you want to read.
But there is one column that can have text values and that is the first column.
So here is the solution:
place text values in the first column.
Note: Cell A1 must stay blank!
You need to read the first column by using the following formula:
size_lookup(Lookup Table Name, "", "not found", Nominal Diameter)
This formula will read for the Nominal Diameter column B and returns the value of column A for the found diameter.
see the result in the picture below:
Hi
But one of my friends solved one of my files with his revit but i can't. Please open attachment
hello @mehrdadjavaheri,
your CSV file has to look like this:
The first column is the Text column that you are going to read.
Change your CSV file and load it into your family.
Change the formula for your Text parameter.
Your formula for Text must look like this: (Remove the the T in the formula)
Hi
But this revit family file works good. if you change the nominal diameter in family the text returns successfully . your solution in good for one text parameter but i want to have two text parameter.
Unfortunately, you can only read the first column from a lookup table as a Text value.
What you could do is read several lookup tables in one family Type.
You only need the first end second (lookup column) in the second CSV file
Test2.csv:
Hi
Revit 2019 now works and return text from lookup table.
I created this lookup file.
,text##other##,description##other##
1,1,Number one - Revit 2019
2,2,Number two - Revit 2019
The results
=size_lookup("lookup", "description", "", "1") return "Number one - Revit 2019" =size_lookup("lookup", "description", "", "2") return "Number two - Revit 2019"
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Also using Revit 2019, but I am pretty sure, you need to add double quotes to your text values in .csv file.
Se my example: http://mgrevitblog.blogspot.com/2018/05/lookup-table-text.html
i came across this post and think with might work for you
