If Load Classifications & Demand Factor aren't showing into Panel Schedule, then what should be the reasons behind it?
I'm putting the Load Classifications & Demand Factor values into the family but whenever I'm extracting the Panel Schedule, it isn't shown over there.
Solved by sujanc. Go to Solution.
You can try the following:
1 - Enter in the schedule template editor
2 - Enter in Set Template Options
3 - Select Loads Summary option
4 - In the Show in panel schedule, check A constant set of load classifications, then check Only loads that are connected to the panel, this sequence will refresh the Load classifications linked to the template
Fábio Sato
Check whether the load is properly connected or not, if not then please connect them in circuit and check.
