Lines drawn over grids not printing clearly
tbagul1
Message 1 of 9
tbagul1
I am facing this issue on multiple projects in multiple versions of Revit.
When I draw a detail line that is aligned with a grid it does not print properly. Only the parts where there is a space between the dash and dot of the grid, the detail line print in its original dark version.
I have attached a screenshots of how it looks in Revit and in PDF.
I have tried the arrange tool in Revit to try and make the detail line to "Bring to Front" and "Bring Forward" but it does not work.
Any ideas on how I can make these detail lines print in normal way?
Any help is appreciated!
Thanks!
Replies (8)
Message 2 of 9
nmarcelis
Are your printer settings set to raster or vector processing?
Revit Certified Professional Architecture, Structure and MEP.
Message 3 of 9
nmarcelis
Try changing this setting. Normally it will fix this.
Message 4 of 9
tbagul1
Hi @nmarcelis
Yes, I tried this. No luck. Any other options that you might have?
Message 5 of 9
Is your grid lines not black?  None black lines will print on top black lines.
Message 6 of 9
tbagul1
@ToanDN - Grid lines are grey. Thre lines that I wanted to print in full are black color.
Message 7 of 9
Yes that was my guess.  I don't see any solutions except using black grid lines, or make them much thinner than the other lines.
Message 8 of 9
hmunsell
In your print Settings, are you printing using Blacklines/Greyscale/Color?
Howard Munsell
Message 9 of 9
tbagul1
@hmunsell I am using Greyscale. I tried using Blacklines but same issue.
