Level difference from the linked model
Dipendra_yadav
Dipendra_yadav
I have linked the architectural model, the elevation in the MEP model shows the different level from the linked arch model.
Unpin and move the link to align with your model. Then acquire coordinates.
robert.klempau
Hello @Dipendra_yadav,
please see your other post for my answer. 😀
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Robert Klempau
Senior Consultant AEC
Cadac Group AEC BV
Mahmoud.Ziedan
@Dipendra_yadav
There are many methods to do this. I believe if you already have the levels inside your MEP model then just align them with architectural levels.
Please if this solved your issue mark it as a solution to help others.
You found a post helpful? Feel free to give it a like!
Your question got successfully answered? Click the 'Mark as Solution' button.
Mahmoud Zeidan
BIM Manager / Mechanical Engineer
benjamin_miranda
First, acquire the link coordinates. If this will not solve the issue then try changing the elevation base under properties palette from Survey Point to Project Base Point or vice versa.
