Is there a way to change the Date/time stamp format from inside a Label?
revitworkbench
revitworkbench
Hello, Is there a way to change the Date/time stamp format inside revit? It gives : 1/25/2017 12:44:38 PM but I want January 25, 2017... can I do that? How?
RobDraw
If there is, I can't find it either.
Rob
robert.klempau
Hello @revitworkbench,
I was thinking of a Dynamo script.
But not yet in the right format. Smiley Sad
I hope I will get it. (asking help on the Dynamo forum)
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Robert Klempau
Senior Consultant AEC
Cadac Group AEC BV
robert.klempau
Hello @revitworkbench and @RobDraw,
Good news:
See this twitter message:
adding a core node that reports DateTime in a specified format
When they added that to the core, you are able to do the job. Smiley Happy
Kind regards,
Robert Klempau
Cadac Group AEC BV
robert.klempau
I have the solution Smiley Very Happy
See the Dynamo script below and in the attachment.
just place it in the Daynamo player when you have Revit 2017.1
Below you see the Python Script:
import sys
sys.path.append(r"C:\Program Files (x86)\IronPython 2.7\Lib")
from datetime import datetime
now = datetime.now()
str_format = IN[0]
OUT = now.strftime(str_format)
# >>>  25-01-2017
See this link for the date and time format string parameters.
Just play with it.
Please let me know if this is your solution.
Kind regards,
Robert Klempau
Cadac Group AEC BV
F_Giorlando
The simple answer then is no you can not.  You have to use Dynamo to change a date format. Geessh. And seven years later, still the same.
