I have table with formula( fixture unit calculation). I want to insert table with formula in drafting view so that I can plot it into the sheet. It has couple of multiplication, addition etc. What is the best way to doing it. I have attached screenshot which I have created in AutoCAD. The table is fairly long. Thank you
you can try to create a new legend and import cad, pdf, jpeg files and can drag to different title block sheets? thanks
Can you not just use a standard Revit schedule which displays and totalises the fixture unit values pulled from the families? Revit will do the calculation for you and update it immediately if anything changes in your model. The schedule can then be placed on any (and on multiple) sheets.
In the schedules you could create the formula to aritmetics and boolean opertaions in the similar way
