Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Importing pipes from Revit to Advance Steel
2 REPLIES 2
YujinXELPG
197 Views, 2 Replies
YujinXELPG
Hey everyone,
I'm having trouble importing pipes from Revit to Advance Steel. I used the pipes available in the System ribbon in Revit and exported them to Advance Steel using the Advance Steel Extension add-in. However, when I imported the "smlx" file from Revit into Advance Steel, only the concrete foundation was imported.
Can anyone provide some insights on why pipes were not imported into Advance Steel from Revit?
Thank you so much!
Hey everyone,
Thank you so much!
2 REPLIES 2
iainsavage
in reply to: YujinXELPG
iainsavage
Never used it but
and
https://help.autodesk.com/view/RVT/2022/ENU/?guid=GUID-5CCA0F7C-FEF1-4599-AC22-161CD06239C9
Seems like it only transfers structural elements?
Never used it but
and
YujinXELPG
in reply to: iainsavage
YujinXELPG
Thanks so much for your thoughts on this @iainsavage
I found this solution yesterday and as you replied, Revit and Advance Steel can only transfer structural members, and a pipe is not a structural member.
Thanks again!
Thanks again!
