Importing .asm File Into Revit Project
Jcully
Jcully
I got a .asm file, of an equipment layout, from an outside contractor and I need to import it into my Revit project. I am using Revit 2023. I found information about a plug-in online called ImportMaster for Autodesk Revit - Creo, but when I try to find the download in the Autodesk App Store, it's not there. Does anyone have any idea how to import this type of file?
Thank you!
DarrenP
do you have Autocad?
DarrenP
Jcully
Yes, I do.
DarrenP
Autocad can import asm files then you export to sat then import the sat file into revit
DarrenP
Jcully
Thank you! I will give that a try!
