IFC Export issue
IFC Export issue
gdasJ7GZU
IFC Export issue
gdasJ7GZU
Security Devices are getting exported as IfcbuildingElementProxy instead of assigned Ifc class. Other Elements like Electrical Equipments are exported correctly.
fabiosato
Have you set the desired classes for each Revit category in IFC export options?
Fábio Sato
gdasJ7GZU
Thank you for response. I have already set IFC class in the IFC options. However, after export I am getting building element class instead of the one I set.
fabiosato
Which Revit version are you using?
Fábio Sato
gdasJ7GZU
I am using Revit 2022
fabiosato
Have you tried to use interoperability tools?
You can specify the IFC class to export to with this tool.
Fábio Sato
gdasJ7GZU
No. I have not tried this. I will try it. Thanks for the information.
