Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
I can not connect Pipe fitting with slope 1/4"
3 REPLIES 3
debimmanager
1185 Views, 3 Replies
I am trying to connect PVC pipe with a size 1 1/4" to a PVC pipe fitting with a slope 1/4". So, I can not connect with slope 1/4" and with slope 1/8" if it works. Anyone knows how to fix this?
Kudo if you consider it and mark as a solution if it helps you solve your issue.
Thank you!!
Deivis E.
REVIT® MEP Specialist
3 REPLIES 3
in reply to: debimmanager
this forum gets a little off topic with some in fighting but its been addressed before. im not sure why its like this, i dont know if revit has thought of addressing it or not. https://forums.autodesk.com/t5/revit-mep-forum/revit-fittings-won-t-make-connection-at-certain-angle...
debimmanager
Hi @Anonymous
I appreciate your reply, but I have already found a solution, you have to change the part type into the family editor. So that, depending what you want it
you have to change it. Right now it works well.
Thank you!!
Deivis E.
awesome, yea thats what i do. duplicate and modify the family accordingly but not everyone does the family editing stuff so i just say you can use the family editor to fix it but i was talking on the phone during that last post and forgot to mention that, my bad.
Forma Design Contest
Technology Administrators
