How to view currently "running" operations/processes... (v2016)
So at the bottom of the window, there is a "status bar" that updates when you switch views, open a project, print a sheet, et cetera. (The green loading bar, to be specific) Currently, there is a background "operation" for printing a sheet that I cannot seem to cancel. It doesn't cause any functionallity issues, and it persists even after closing and reopening Revit. Is there a way to view current "operations"/"processes" so that I can cancel the sheet printing?
If I hold the ESC key, the status bar rapidly switches between the no selection status and the loading bar for printing the sheet.
Thanks in advance,
P
ennujozlagam
hello you can try to press ESC (a few times) and see if helps. thanks button.
