How to Modify Connection Type for Pipe Fittings or Sections
15132569893
15132569893
绘制管道后,如何更改“属性”面板中的连接类型?如图中位置所示
Translation:
I would like to inquire about the location or procedure for modifying the Connection Type property for a pipe fitting or section. Specifically, I am looking to set or change the connection type (e.g., welded, threaded, grooved, glued, soldered, flanged) within the system. Could you please advise where this setting can be accessed or modified? Any guidance or documentation reference would be greatly appreciated.
iainsavage
Do you mean that if I modify the pipe material and routing preferences, the pipe connector types will update automatically?
iainsavage
I mean that you had another post with exactly the same title and I don't understand Chinese(?) so I assumed that this latest post was on the same topic as the other one.
Why did you create a whole new post (in Chinese(?)) rather than replying to the other post?
Connection type parameter is always "Generic" as far as I can determine and it is a built-in parameter that you can't alter.
Per your other post, create the pipe type that you want and give the type a descriptive name to identify the type of connections, for example "Steel Schedule 40 Welded" etc.
You can also put some text in one of the parameter fields such as Type Comments, Description etc.
Or you can create your own shared parameter.
