Different Annotation Graphic Based on Phase
TVillafrancaT9SJL
TVillafrancaT9SJL
I have an annotation graphic, and I also have a filled region drawn into it, how can i make the filled region only appear when the phase of the family is in "New Contruction" ?
mjohnsonWCNJU
Annotation graphics cannot have phase assigned to them, only model elements can have phase assigned. Either way you could do it by making a new type to show/hide this based on what you select. Not as ideal since you'd have to manually change, but here's how you could do it:
  1. Edit the family to add a new Yes/No parameter
  2. Click on filled region (or whatever you want in family to be hidden or shown based on type)
  3. Click on the = button right of Visible, then assign that to the parameter you just created
  4. Then load family into project, and make a new type that has visibility toggled how you want it to be
Matt Johnson - Founder of Thermist
TVillafrancaT9SJL
Thanks for the response and detailed explanation Matt, This was my suspicion but I wanted to have it confirmed by others.  Have a good one !
curtisridenour
I think a more robust solution would be making view filters to display different filled region overrides based on Phase Created parameter. You can make them Model Category specific or apply logic to other parameters
