How to customize one column electrical branch panel schedule as per authority regulations. Sample attached.
anish.mep
anish.mep
Is there any option to split the db schedule as per attached sample.
Thanking you for the effort taken to answer my question.
nmarcelis
Hello this is almost impossible.
It is best te recreate this manually in an external program/excel.
Revit Certified Professional Architecture, Structure and MEP.
anish.mep
it is possible up to 80%, i did it. Check the attachment as i tried a sample.
*The pending is footer side were i am unable to add the columns of the diversified loads.
**And not able to split the db.
***Any one can suggest how to get total sum of the column.
hmunsell
unfortunately, I find that in a lot of regulatory type requirement. They have really old standards/formats for things, and it is hard to accommodate all of them. Revit will get you 80-90% there, but there are just some things, that these old requirements want, that can't be done.
in some of these cases we are able to work with the client. We explain were using Revit, and why we prefer to use Revit, and how it works. we can sometimes get them to accept the Revit schedule if we can show the same information is there, it's just in a different place. Sometimes they work with us, sometimes they don't. but its worth a shot....
Howard Munsell
dbutts7
I've found that using DiRoots to dump electrical circuit scheduling data to Excel, making what changes I can and bringing it back in allows me to use the circuit data while presenting in another format/view type. But the better long answer is to get the authority to update their table.
thanks - David B.
David A. Butts
Virtual Design and Construction Manager - Kimley-Horn
Revit Certified Professional/Autodesk Certified Instructor
Revit, AutoCAD Architecture, MEP, Plant 3D, BIM Collaborate Pro Subject Matter Expert
The MEP BIM/CAD Engineer Blog
