Simply make an empty annotation family, label it "LEADER" and when you insert it, set "Number of Leaders" to 1, or howerver many you desire.
Regards
A quick and dirty workaround, which seems to work just fine in practice for user Keynotes for example, is to Clipboard copy the tag/leader and then immediately paste back "Aligned to same place". Then reposition one leader.
Does anyone know how to create an airplane?
Yes, take all the wheels off your car and have 4 of your strongest friends carry each corner. They will get tired, so have a bus full of other friends follow along. Turn the bus upside down, and have monkeys row it with kayak paddles.
Call it Revit.
Autodesk... you are wearing clown shoes. You've had over a decade to make this thing work. Any of the previous upgrade price years would have been a good time.
I'm using Revit 2019 so i don't know if this works on previous versions.
Leader with no text
Create text with any letter In it
Add Leader line to the text
Delete the letter from inside the text box.
The leader stays with a blank box
I found a legit way to do it
-Go Click on the Revit 'R" Symbol,
-Go to New
-Click Annotation Symbol
-Create a circle or whatever shape that suites you (if you need the shape even better you can skip the next step
*-use viability parameter to hide the shape if required (this could be quite advanced for new users)
-Create->Family Category and parameters make sure Generic Annotation is selected
-load into project, when you click on the new symbol there will be an option to add a leader to it.
Or, simply start a text with leader command and ESC instead of typing in text.
Toan Nguyen
Toan Nguyen
@brett_73 wrote:I'm using Revit 2019 so i don't know if this works on previous versions.
Leader with no text
This seems to only work in versions 2017 and later. Just tried it in 2016, the entire object is deleted once you exit the empty text box .
Why not create a new family-generic annotation. delete the text and save as "leader without text" or something similar. works for me.
