How to control a check box in a revit family with another check box
Jrooker06
Jrooker06
How can I control a check box with a if/and formula in a revit family using another check box?
Example: I would have (4) Yes/No check boxes in the family (Switch 1, Switch 2, Blue, Yellow). When I check the box Switch 1, I want it to check the Yellow box and uncheck the Blue box. When I check Switch 2, I want it to check the Blue box and uncheck the Yellow box.
PavelAnd
Hi @Jrooker06. You needn't 2 switch checkboxes. Just write not(Blue) to Yellow formula.
Or use one switch checkbox.
Don't use if in formulas. Write only conditions. See example below.
Best regards, Pavel Plotitsyn.
Mohamed-Nassar
Boolean parameter
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
amarkonathala
Follow The Above  Condition It might helps
Thank you
jfuller9K7VX
Is it possible to still use the Check1 & Check2 controls but enable the colour yes/no for selection (so the Check1 & Check2 are grey & the colours are selectable)
