how is it done (dimension linear angle)
Message 1 of 9
Replies (8)
Message 2 of 9
RobDraw
More words please. A picture showing what you want would be even better.
Rob
Message 3 of 9
Mohamed-Nassar
From Annotate tab > Dimension
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
Message 4 of 9
Message 5 of 9
RobDraw
That is actually called Arc Length in English. It seems to be limited as to what kind of objects you can dimension, though.
Rob
Message 6 of 9
in the example in degrees. How to change length to angle?
Message 7 of 9
RobDraw
Huge language issue here. Isn't there a forum in your native tongue?
If you look at my image again, three icons to the left of the one I underlined is the Angular dimension but that seems too simple. Is that what you are after?
Rob
Message 8 of 9
I had to press yellow
 thanks
Message 9 of 9
RobDraw
That's another way but it may not be an option depending on what you are dimensioning.
Rob
