How does Revit calculate Wall Assembly R-Values?
- Mute
- Permalink
- Report
I entered an Interior-5 1/2" Partition wall. The total default R-Value of the wall didn't seem to make sense, so I am trying to understand how Revit calculated R-Values. I have found at least 4 different sources that rate 5/8" of gypsum board with an R-value of at least 0.5. To test this in Revit, I reduced the metal stud layer to effectively zero and left only 3 layers of Gypsum Wall Board. According to Revit, this wall only has a resistance of 0.4160. How does 3 layers of Gypsum Wall Board have a smaller R-value than all the other sources I have found for only 1 layer? I also found another source that lists the thermal conductivity of Gypsum Wall Board at 0.17 btu/(hr·ft·°F). Revit lists this at 0.3756 btu/(hr·ft·°F). Why such a large difference? At 0.17 btu/(hr·ft·°F), the total R-Value is much closer than indicated by several other sources.
