How do I change the length of a custom pipe by dragging the connector dots?
Message 1 of 8
I'm trying to connect the end of a custom stab in pipe to an elbow but it's not letting me change the length of the pipe by dragging it. The only solution I found was to change the length manually through the properties but it's really slow. Any help would be greatly appreciated!
Replies (7)
Message 2 of 8
RobDraw
Can you align it to anything? If nothing is available, you could use a reference plane. Could be useful if you have multiple stub ins.
Rob
Message 3 of 8
iainsavage
Just grab the end and drag. Can’t think why that won’t work.
Unless you are talking about Fabrication Parts rather than Revit pipe
Message 4 of 8
That's right, its a MEP fabrication part made through CADmep. Is there any way to make it draggable?
Message 5 of 8
iainsavage
Not my area of expertise I’m afraid, I don’t use fabrication parts.
Message 6 of 8
They're all at different lengths so I'd need to make new reference planes everytime. But thanks for the suggestion
Message 7 of 8
RobDraw
Sorry, haven't worked with fab parts. Nothing more to add.
Rob
Message 8 of 8
motherwellk
It works with our Database Pipe Items. Try unlocking the connectors in the Item file.
