How can I override the dimension text?
Solved by www.TechRoom.bg. Go to Solution.
Simple answer, you can’t.
If you need so bad to change dimension value you can set dimension style to show very little text (barely hide) and you can put manual text with new value of dimension.
I hope this will help you!
Eng. Iliev L.
⁞|⁞ BIM Implementer, Project & BIM Manager, Coordinator, MEP Engineer
⁞|⁞ http://www.TechRoom.bg
Actually you can, but you shouldn't, unless you need to include some notes.
If you single click the dimension number, get the cursor close to the dimension number, click inside the rectangle that appears surronding the text, you get the override screen.
Fábio Sato
