How can I import/load a .csv file as a .rfa (family) file?
haggarwalUS3A5
haggarwalUS3A5
I am following this tutorial - https://www.autodesk.com/certification/learn/course/revit-mechanical-modeling-system-design-professi...
and they loaded fitting files like "Cap - Threaded - MI - Class 150.rfa" from within the installation folder of their software.
I am using the latest trial version and instead of family files, I have .csv files. So for example, instead of "Cap - Threaded - MI - Class 150.rfa", I have "Cap - Threaded - MI - Class 150.csv" in my directory.
How do I use these .csv files to load whatever fittings I want?
iainsavage
Those .csv files will be either a type catalogue or a lookup table which accompany the .rfa files to drive geometry etc.
You still need the .rfa file as well.
haggarwalUS3A5
Thanks for the quick reply! Is there a place where I can download those official .rfa files?
Also is it possible that I don't have access to these files because I am using a trial version?
haggarwalUS3A5
Thank you so much! The first link worked perfectly for me
