Help..!! How to delete duplicate tags of any object (Pipe/Duct)?
Message 1 of 16
I am facing a problem in my current project. Unfortunately, there have two tags for every single pipe & ducts etc. I want to keep only one tag for one object. How to remove all repeatative tags?
Paranjoy Mitra
Replies (15)
Message 2 of 16
kadmonkee
there is no easy solution.
select all the tags you want to delete using the CTRL key then delete them
select one tag right click select all in view delete all.
if they are 2 different tags then choose wisely
delete all tags then tag all by category and select the correct tag in the pull down options.
on the Annotate Tab find the Tag All button.
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Message 3 of 16
Hi Kadmonkee,
Thanks for your prompt reply. Actually your solution will take too much time & I have to do this job for my whole project with in very less time.
Message 4 of 16
kadmonkee
select and filter all tags delete them and use the TAG ALL feature takes minimal time.
it is placing the tags after initial placement that takes time.
good luck
thank you
Message 5 of 16
Highlight the tag you want to delete from Browser, right click and select Select All in Project, then change the them to the type you want.  Repeat for each one you want to delete.  When done, you can delete the unwanted tag types/families from browser, or Purge them.
Message 6 of 16
Hi ToanDN,
Thanks for your reply. But my query was something different. Suppose there have a pipe in a project. It has two tags and both are same family (like "32mm CWS" -this tag provided two times for that single pipe). Now you can imagine how much rework will be there for the entire project. So, to minimise the time, which method we can follow.
Message 7 of 16
Can you delete all and re-tag all?
Message 8 of 16
kadmonkee
can you confirm there aren't actually 2 pipes (1 on top of the other)?
using a crossing window (right to left dashed border selection) select a small section of pipe look at the properties it will give you a total count of selection.
delete all Tags and use TAG ALL by category as recommended earlier.
thank you
Message 9 of 16
i have already checked that. There have single element only for sure. Only tags are multiple for same pipe.
Message 10 of 16
kadmonkee
it seems that they were tagged twice the only solution here is to delete them and use the TAG ALL option or delete  each instance of the duplicated tag
if it is broken and needs to be fixed time is not an issue
thank you
Message 11 of 16
Yup.. how ever thanks a lot..
Message 12 of 16
pawel.romaniuk
Hello @Anonymous
Alternative solution can be deleting duplicates elements with Dynamo and we are not talking only about Tags...
https://www.youtube.com/watch?v=koO22fB1abI
Here you can get more infomration about Dynamo scripting
http://dynamoprimer.com/en/
Please try it out if it will be siutable for you.
Pawel Romaniuk
Message 13 of 16
Hi @pawel.romaniuk,
A big thanks for sharing this information. But i am very specific on "How to delete duplicate tags?" If there have no options currently, please try to add this feature also for 2019 version. Thanks again.
Message 14 of 16
RobDraw
Okay, we users at this forum will get right in it and make sure that happens.
Rob
Message 15 of 16
Thank you so much.. For your information this feature is already available in Autodesk Fabrication. There we can't provide same tag for same object twice.
Message 16 of 16
RobDraw
That would be a different feature.
How can you delete duplicate tags if you can't create them to begin with?
Not being able to have more than one tag for an object would be an unacceptable limitation in MEP.
Rob
