heating and cooling loads command missing after enabling it in revit.ini file
ElisabettaCleri
ElisabettaCleri
Community Visitor
Community Visitor
Hi fellas, I tried following the procedure showed in the link https://rippleengineeringsoftware.com/revit-heating-and-cooling-loads-in-revit-2022/ ...and yes I saved after pasting the command lines, but really cannot find it in the tabs.
Can someone tell me what the heck am I missing?
iainsavage
There might be more than one version of the ini file, the one you want is I think
C:\Users\[USERNAME\AppData\Roaming\Autodesk\Revit\Autodesk Revit 2022
ing_rcoronel
Community Visitor
Community Visitor
Yo hice asi mismo y tampoco me funcionó, yo tengo en la versión en español
iainsavage
@Kevin.Lawson.PE has advised, and its in the official help, that the version must be 2022.1 or later.
Check your version/build.
ing_rcoronel
Community Visitor
Community Visitor
C:\Usuarios\[NOMBRE DE USUARIO\AppData\Roaming\Autodesk\Revit\Autodesk Revit 2022
Utilice este mismo enlace y no encontre la otra version de ini
Gracias por la respuesta
ing_rcoronel
Community Visitor
Community Visitor
Quice poner no encontre
iainsavage
Do you have version 2022.1 or later?
¿Tienes la versión 2022.1 o más reciente?
