Local file is not compatible with central model issue
chongji.koh
chongji.koh
Hi I'm working on a cloud sharing project and I keep getting this when sync my model file now and then. And when this happen, I have to close the file and reopen the latest model without sync to central in order to open the file. This keeps happening  once in a while when I'm working on the model, but now it is becoming so frequent so much that I need to reopen the model file for more than half a day before this pop up don't happen.
May I know what cause this issue and how to rectify?
Make sure everyone working on the model having the same update.
chongji.koh
We make the same updates but it doesn't seem to work
chongji.koh
We make the same updates 2 days ago and it doesn't seem to work
hmunsell
@chongji.koh wrote:
...I have to close the file and reopen the latest model without sync to central in order to open the file.
by closing with out sync'g and and then reopening it, it is making a new local, which is one of the recommendations in the warning message. How many others are working on the file?  Could someone be working offline/locally and then uploading the models instead of working in Cloud Sharing environment?
Howard Munsell
RobDraw
The easy fix is to delete, or move the local. By doing this, Revit will create a new local. If it continues to be a problem, make sure everyone is on the same Revit build and is following proper synching procedures.
Rob
