heating and cooling loads command missing after enabling it in revit.ini file
ElisabettaCleri
Message 1 of 9
ElisabettaCleri
Community Visitor
Community Visitor
Hi fellas, I tried following the procedure showed in the link https://rippleengineeringsoftware.com/revit-heating-and-cooling-loads-in-revit-2022/ ...and yes I saved after pasting the command lines, but really cannot find it in the tabs.
Can someone tell me what the heck am I missing?
Replies (8)
Message 2 of 9
iainsavage
There might be more than one version of the ini file, the one you want is I think
C:\Users\[USERNAME\AppData\Roaming\Autodesk\Revit\Autodesk Revit 2022
Message 3 of 9
ing_rcoronel
Community Visitor
Community Visitor
Yo hice asi mismo y tampoco me funcionó, yo tengo en la versión en español
Message 4 of 9
iainsavage
@Kevin.Lawson.PE has advised, and its in the official help, that the version must be 2022.1 or later.
Check your version/build.
Message 5 of 9
ing_rcoronel
Community Visitor
Community Visitor
C:\Usuarios\[NOMBRE DE USUARIO\AppData\Roaming\Autodesk\Revit\Autodesk Revit 2022
Utilice este mismo enlace y no encontre la otra version de ini
Gracias por la respuesta
Message 6 of 9
ing_rcoronel
Community Visitor
Community Visitor
Quice poner no encontre
Message 7 of 9
iainsavage
Do you have version 2022.1 or later?
¿Tienes la versión 2022.1 o más reciente?
Message 8 of 9
lorenzomasottiarchitetto
Observer
Observer
Hello @iainsavage  I am trying to find it but I have no Ini.file in my folder.Her the screenshot, inside  Revit file (here selected) but inside there is not the Heating and cooling....
Message 9 of 9
iainsavage
That Revit file that you have highlighted IS your Revit.ini file, you just haven't configured Windows to display file extensions:
The Heating & Cooling Loads tool has been retired since version 2022.1 in favour of the more advanced and more accurate Systems Analysis method, that is why the Heating & Cooling loads tool is not present by default. You can reactivate it using the method in the links above but it is no longer supported or developed. The recommendation is therefore to use systems analysis.
