Having multiple connectors to an air terminal,unable to compute pressure drop
Hello, I made a slot diffuser with array connectors (multiple connectors) it perfectly worked, but during pressure drop calculations, if more than one connection is set , the Revit shows a message "not computed" Can any one have a solution.
mhidshaji
Make separate diffuser for each connector portion of a slot diffuser.
marco.defina
ihave the same issue and Autodesk opened a case after my report:
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
The Development Team will try to make an initial assessment. The fix requires the code for Revit to be modified, and as such, we do not have a timeline for when any fix may be released.
The solution of @mhidshaji is the only solution at the moment.
BIM Manager - HVAC and Plumbing designer https://www.autodesk.it/content/dam/autodesk/www/products/responsive-imagery/responsive-badges-compare/2019/navisworks-manage-2019-badge-75x75.pngApp AutoCAD per dispositivi mobili premiumNavisWorks Simulate3ds Max___________________________________________________________________________
Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums.
