Editing linked architecture model visibility
Message 1 of 12
I am part of an mep firm and am working on a linked architecture file. When I brought the file in no room tags or anything are shown. When I go into V/G and check everything (in the model and revit links) nothing seem to be affected by the changes. I just started a couple week ago, anybody know what's going on?
Replies (11)
Message 2 of 12
RobDraw
Yup.
Annotation type objects don't always come through links. If you are willing to just reference the architect's tags, you can set the link to display by a particular "linked view" in the V/G overrides. The first row in the first tab of the link overrides is where you would do that.
Alternatively, you could tag the rooms in your model with a tag of your choosing.
Or, you could do what @ToanDN says below.
Rob
Message 3 of 12
Follow the steps below to pick an applicable from the link model where they show the annotation like Room Tags.
But that may turn on things you don't need.  In such case, just tag the Room directly in your views.  Or create Spaces and tag them.
Message 4 of 12
I need to know where the elevators are is why I need their room tags and can't make my own. I tried what @ToanDN showed and the floorplan was still unaffected. How can I reference the architects tags when I don't see them?
Thanks for responding!
Message 5 of 12
That didn't affect my view. Nothing in the V/G seems to affect my view.
Message 6 of 12
RobDraw
You really shouldn't need tags for that.
@Anonymous wrote:
@ I tried what @ToanDN showed and the floorplan was still unaffected. How can I reference the architects tags when I don't see them?
Does the architect's model have tags? You need to reference the same view.
Rob
Message 7 of 12
RobDraw
You might be in trouble.
Rob
Message 8 of 12
If you only need to find where a Room is then do a Tag All on your view. Or create a room schedule that includes links, find locate the room name, select the row and Highlight in model. It will take you to that room.
Message 9 of 12
RobDraw
I've never been able to get tag all to work for rooms in a linked model.
Rob
Message 10 of 12
When I open the architecture file by itself I can't find any tags from there either.
Message 11 of 12
RobDraw
That is the problem!
Rob
Message 12 of 12
RobDraw
So, the real solution is to get the architect to put in the room tags and use the method first mentioned.
Did the architect even put rooms in?
Rob
