hanger placement
hanger placement
jlambert
Message 1 of 8
hanger placement
jlambert
So I am trying find a way with out a paid add on to place hangers on conduit runs.
  1. I would like to be able to attach a hanger family to the bottom of conduit with out putting in a elevation.
  2. would like to know if there is away to do a array on hangers that would take the path of the conduit.
Any ideas or help would be appreciated.
Replies (7)
Message 2 of 8
L.Maas
Then you could create a face based family. However you would still have to add elevations. Because the family probably will need values to stretch it up to the ceiling/roof/floor.
An array in Revit is always straight or circular. An array can not follow a path.
If you do not wan to spend the money you could write your own add-in. Or have a look at Dynamo. There probably are some scripts out there that can help. Have a look at the Dynamo forum for this.
But having to do this on regular basis a paid add-in might be a good ROI.
Louis
Please mention Revit version, especially when uploading Revit files.
Message 3 of 8
Kelsey.S
Autodesk Support
Autodesk Support
Hi @jlambert,
I was just checking to see if you got your questioned answered.
Please mark any posts that help with "Accept as Solution" and thanks.
Kelsey Skaug
Autodesk Technical Support
Message 4 of 8
s.borello
How often do you need to model supports?  An add-in could save you countless hours if it's something you do often.
Message 5 of 8
Kelsey.S
Autodesk Support
Autodesk Support
Hi @L.Maas
I was just checking back again to see if you got your questioned answered.
Kelsey Skaug
Message 6 of 8
KrisAribal
or create his own hanger model plus create a Dynamo script that let's him copy or array the said hangers by picking spline or line.
Message 7 of 8
jlambert
This sounds like a good idea I have a hanger family I just need to know how to do the script in dynamo or as a macro.
Message 8 of 8
KrisAribal
