Hi @jelmer.eekman,
What you could try is the following:
Go to your Mechanical Settings and make sure your MEP Hidden Lines are checked. Also, make sure that you assign small or smaller values opposed to what you currently have.
Is your Visual Style set to Hidden Line?
I hope this helps and if it didn't resolve you issue, let me know!
Rudi Roux
MSc | Digital Engineering Manager
LinkedIn
Revit Mechanical & Electrical Systems 2018 Certified Professional | Revit MEP & Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional | Autodesk Building Performance Analysis (BPA) Certificate
If this post resolved your issue, kindly Accept as the Solution below. Kudos are always welcome ⇘
