Why are my fire alarm sysmbols shown in plan view opposite in ceiling view (please see attached)?
Any suggestion/comments will be much appreciated.
Solved by CoreyDaun. Go to Solution.
Hi Corey,
Please see attached family as requested. I am using Revit Version 2013.
In your Family, disable "Maintain Annotation Orientation" - you can find this under Properties with nothing selected OR by going to Family Category and Parameters. This behavior is due to the Reflected Ceiling Plan viewing the object from the opposite direction with Revit trying to maintain the appropriate orientation.
It's a case-by-case setting - enable it if you need it. I can't immediately think of an example of when I would want to enable this option.
