Revit MEP Forum
Fire Alarm Symbol Plan vs. Ceiling
5 REPLIES 5
bvm76
2647 Views, 5 Replies
Why are my fire alarm sysmbols shown in plan view opposite in ceiling view (please see attached)?
Any suggestion/comments will be much appreciated.
Please mark Accept as Solution if your question is answered!
Thank You.
5 REPLIES 5
CoreyDaun
in reply to: bvm76
Could you attach your Family file? Also, what version of Revit are you using?
bvm76
in reply to: CoreyDaun
Hi Corey,
Please see attached family as requested. I am using Revit Version 2013.
Thank You.
CoreyDaun
in reply to: bvm76
In your Family, disable "Maintain Annotation Orientation" - you can find this under Properties with nothing selected OR by going to Family Category and Parameters. This behavior is due to the Reflected Ceiling Plan viewing the object from the opposite direction with Revit trying to maintain the appropriate orientation.
bvm76
Great!
What is the main purpose of this and when to use it?
Thank You.
CoreyDaun
in reply to: bvm76
It's a case-by-case setting - enable it if you need it. I can't immediately think of an example of when I would want to enable this option.
Forma Design Contest
