Hello all,
When I placed a fire alarm panel into the plan it
show just fine on all of the drawings and 3D views.
But I then realized that the Fire Alarm panel was in the wrong category (It was under Fire Alarm Devices). When I set the correct category for the Fire Alarm Panel (Electrical Equipment- Other Panel) the annotation symbol for the Fire Alarm Panel disappeared. While in a 2D view I can still click the panel in the location that is supposed to be but I cannot see the annotation.
I checked the visibility graphics and I have Electrical Equipment,Fire Alarm Devices, and Annotation turned but the symbol still does not show.What could be causing this problem because I am not sure what would be cause the symbol to not appear but for the object to still be available for selection in the view. Below is a picture of the problem I am having. As you can see the model is there but the symbol does not show up. This only happens when the Category of the Family is set to Electrical Equipment instead of Fire Alarm Device.
