Fine Detail as Default in all new views
kzalec
kzalec
I would like to set "Fine Detail" as the default for all new views in Revit.  Is there a way to do this WITHOUT using a view template?  I do not want to use a view template to do this, nor do I want to copy views.  Thanks in advance.
L-Vettz
Manage tab > Additional settings > Detail level.
Set all the scales to fine with the little move arrows. This should do what you are asking.
-LV
sujanc
I think it is not possible without using any view template. But you can do one thing Go to manage tab>additional setting>detail level , here you can add the scale in fine view as per your requirement. Hope this will work.
Please select "Accept solution" if the information was helpful (This allows other users with the same issues to find it higher in search results), or reply back if you need more help!
RobDraw
Rob
