Filling a family by Filter
marco_morazzini
Message 1 of 8
marco_morazzini
Hi all,
I have an electrical equipment object and I would like to fill the surface using a filter.
I applied a filter but I do not see any change(already tried to disable the other filters, but not worked)
Can you suggest me some points to check? As well modifying the family.
Replies (7)
Message 2 of 8
RSomppi
Can you be more specific about what you have, what you want, and what you've tried?
Sharing the family would help tremendously.
Message 3 of 8
marco_morazzini
I have this object
And It should be filled by blue colour.
I tried to do that applying a specific filter to the object but It does not work.
I turn off all the filters applied and tried to have a look at the Visibility settings but I have not found a possible solution.
Can you please give me some more options to consider?
Message 4 of 8
RSomppi
Not without more information.
Message 5 of 8
jessem5CN9L
That sounds more like a family editing issue than a filter issue. Have you tried editing the family and adding a annotative region?
Message 6 of 8
RLY_15
Can you check a few things:
View Discipline
Filter rules
Filter VG settings (including whether or not the surface has a solid fill applied)
Does the family have an embedded family of a different Category
View Range (is this cut or surface)
Message 7 of 8
hmunsell
Here is how I have mine set...
Howard Munsell
Message 8 of 8
The family need a surface or a filled region visible for the filter to work.  Share it if you are not sure.
