Can I group families under a sub-category?
I have received the two highlighted families from a vendor and I would like to put them together under a sub-category called 'Coolers'. Is this possible? I have many more and would like to keep them all together.
Solved by iainsavage. Go to Solution.
Solved by S.Jebakumar. Go to Solution.
You could change the name of the families and give them a prefix so that in alphabetical order they are grouped by prefix.
I'm sure I did this before using DiRoots One Family Reviser:
