Revit MEP Forum
Families: Mechanical Equipment sub-categories
4 REPLIES 4
stu_bas
253 Views, 4 Replies
stu_bas
Can I group families under a sub-category?
I have received the two highlighted families from a vendor and I would like to put them together under a sub-category called 'Coolers'. Is this possible? I have many more and would like to keep them all together.
4 REPLIES 4
S.Jebakumar
in reply to: stu_bas
S.Jebakumar
@stu_bas it is possible to add sub-categories to the Families under parameters. But to Organize them under sub-categories in Project browser is not an option as the families uses system Default Family Category and cannot be over written.
Jebakumar
BIM Specialist
Jebakumar
BIM Specialist
stu_bas
in reply to: S.Jebakumar
stu_bas
OK, thanks. It's a pity but thanks for taking the time to reply.
iainsavage
iainsavage
You could change the name of the families and give them a prefix so that in alphabetical order they are grouped by prefix.
I'm sure I did this before using DiRoots One Family Reviser:
stu_bas
in reply to: iainsavage
stu_bas
That's quite a good idea. Thanks for the suggestion.
