Exported dxf color didn't tally with Revit elements.
Radish_G
Radish_G
Dear Community,
Recently I came across the above-said problem.
While I export a sheet from Revit to .dxf the Duct Accessories Tag Text colour & and the transparent fill pattern of the duct accessories didn't export correctly.
The following screenshot for your kind review and advise.
If anyone got the solution to fix this problem, kindly advise me.
Regards
Radish G
BiMBoXiT
Hi try with this option (see image) should be OK. if any further issues please let me know.
If my post answers your question, Please click the "Accept as Solution" Button. This helps everyone find answers more quickly!!!Snap1.JPG
BiM BoXiT
Radish_G
Hi @BiMBoXiT ,
I did follow this.
It's not working for me.
Regards
Radish G
Daniel_ADSK
Hi Radish G,
May I know which version of Revit you are using?
Please check out this article below for the right workflow:
Specify Colors for DWG/DXF Export
Modify Layer Mapping for DWG/DXF Export | Revit Products | Autodesk Knowledge Network
It looks like a bug if it the problem persist.
Daniel
Daniel Dong
AEC Product Support Specialist
WWFO-Customer Success Organization
Radish_G
Hi @Daniel_ADSK,
Thanks for the reply.
I am using R 2016
I am using BYLAYER and overrides BYENTITY while export.
I think it's a bug as well.
Regards
Radish G
